Tire Dressing
Old Jan 26, 2003 | 02:24 PM
Ernest's Avatar
Ernest
Default Tire Dressing
OK what is the best tire dressing most of the guys are using?Armour All washes off whenever the car gets washed. :yesnod:
Old Jan 26, 2003 | 02:48 PM
rayosequis's Avatar
rayosequis
Default Re: Tire Dressing (Ernest)
I don't really use this on my vette much, but my brother uses Tire Wet, I think its by meguiars (?). BTW, like the name. :)
Old Jan 26, 2003 | 04:28 PM
Red Dwarf's Avatar
Red Dwarf
Try Meguire's Endurance. It's the best I can find. ;)
Old Jan 26, 2003 | 04:33 PM
Dudeurgettnavette's Avatar
Dudeurgettnavette
Black Magic :yesnod:
Old Jan 26, 2003 | 04:44 PM
vader86's Avatar
vader86
Default Re: Tire Dressing (Dudeurgettnavette)
Black Magic, it will take you a couple coats but theyll shine for almost a week barring bad weather.
Old Jan 26, 2003 | 05:50 PM
KyleBst264's Avatar
KyleBst264
Default Re: Tire Dressing (vader86)
IMO, Black Magic is the best. Even though it is a little more expensive, but you get what you pay for.
Old Jan 26, 2003 | 08:49 PM
MIke350's Avatar
MIke350
Default Re: Tire Dressing (lou sylvestri)
:iagree: works good for me
Old Jan 26, 2003 | 10:59 PM
spdrcrj's Avatar
spdrcrj
Default Re: Tire Dressing (MIke350)
I use Meguire's Endurance as well. It's a pain using it on the Goodyear Eagle F1's though and on runflats because of the vertical lines on the sidewalls.
Old Jan 26, 2003 | 11:12 PM
Dan Parker '96's Avatar
Dan Parker '96
When I wash my car the tires get the Westley's Bleche-White (that's how they spell it) treatment. It (plus a quick brushing) removes all dirt and gunk collected from whatever tire treatment you've choosen.
As far as a tire treatment, I've found STP's Son-of-a-Gun to work pretty well. It leaves no shine. Just makes the rubber really black. ArmorAll has a funky smell that negates my using it for anything. Black Magic I've used on my previous Vettes that had the semi-oxided and/or wax filled black rub rail. It worked well for that.
[Modified by Dan Parker '96, 10:15 PM 1/26/2003]
Old Jan 27, 2003 | 11:47 AM
no_radio's Avatar
no_radio
Default Re: Tire Dressing (spdrcrj)
The Maguire's Endurance left a pretty nasty build-up when I used it on my '74. Part of the problem may have been that I showed it several times in a row with very little driving or washing in between, but it had built up, especially around the lettering and other raised areas. Had to scrub it off, and I am now using armor all.
Jeff
Old Jan 28, 2003 | 03:34 PM
DINO's Avatar
DINO
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I went to Cruise-In V with Vetteweiser
Meguires' Endurance is definately the best doesn't splash back from the tires when you take off like all the rest of them :thumbs:
Old Jan 28, 2003 | 04:31 PM
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
Default Re: Tire Dressing (DINO)
I'll be different here, I use Zaino tire dressing, minimal build up, good sheen and seems to last :cheers:
Old Jan 28, 2003 | 05:12 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
:iagree: me too
Old Jan 28, 2003 | 05:52 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: Tire Dressing (C4DC)
I use the foam spray. Lasts long enough for the shows.
Old Jan 28, 2003 | 06:11 PM
1320dance's Avatar
1320dance
i use meguiars endurance stays off my brake system :party:
Old Feb 1, 2003 | 01:01 AM
MaSTeRofDZaSTeR's Avatar
MaSTeRofDZaSTeR
From: "Drive like Hell, you'll get there faster." Tucson AZ
Meguiars Gold Class Endurance High Gloss. Simply put, you can throw out everything else. This stuff is THE SHIZ. Seriously. This stuff has been out for about 2 weeks and as far as I know is pretty damn new. I used this stuff right when it came out. I used like 3 coats on all four tires and my tires are still pitch black and shiny. Every morning I go out and spray em down with a light water mist and they're ultra black with a heavy shine. Think about the fact that I live in AZ and the roads have probably the most dust and dirt of any US road system. And the best part about it is that unlike other tire cleaners and shiners.........this stuff lasts for weeks. Literally. I haven't had to reapply this stuff yet. It's been about 2 weeks. The cost of it is about 6-8 bucks and I've only used about 30 percent of the bottle at most with a triple coat of all four tires. BTW I've used just about every tire cleaner and shiner on the market..... they all had to be reapplied in like 2 days, most had to be reapplied the next day for optimal shine and coverage. And the others cost either the same $$$ or more. Meguiar's Gold Class RULES in this category. :thumbs:
Old Feb 1, 2003 | 01:06 AM
MaSTeRofDZaSTeR
Default Re: Tire Dressing (MaSTeRofDZaSTeR)
I think the Endurance cleans too, but you should have it applied on clean wet or dry tires. I do use Bleche-White on the tires first BTW and the tires in my sig are PRE-Endurance application. In other words they were dry as a bone before Endurance apps. I just haven't had the time to get more recent and/or better pics yet.
To Tire Dressing
Old Feb 1, 2003 | 10:18 AM
rubyred93's Avatar
rubyred93
I think that the "best" tire dressing is rather subjective. It really depends on the look that you are after(baby oil dressed vs. new tire sheen or somewhere in between). Also, how much "sling" are you willing to put up with? Some tire dressings will sling onto body panels more than others, and that's just another mess to contend with.
I have a shelf full of this stuff, and have experimented with many brands. Personally, I prefer Vinylex on my Vette tires. It has a nice/moderate shine, no sling and provides UV protection. Application is simple and smooth.
The Zaino Perfect Tire Gloss is also a nice choice, but will provide slightly less sheen. If you are in search of a new tire look, then Zaino Perfect Tire Gloss would be worth taking a look at, as well as 303 Aerospace Protectant.
Eagle One used to produce a tire dressing called Concours Satin Finish, and that provided the lowest sheen that I have seen to date. They no longer
produce it, but have replaced it with their general protectant (not the same, if you ask me).
I've also tried the Meguiar's Endurance that everyone is speaking of. As far as a readily available dressing, it's okay but would not be my first choice. :steering:
Old Feb 1, 2003 | 10:41 AM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
Default Re: Tire Dressing (rubyred93)
Stoners is the best...Period! :yesnod:
Old Feb 1, 2003 | 10:48 AM
Phil-tha-Rush's Avatar
Phil-tha-Rush
Default Re: Tire Dressing (Hardcorvette)
:iagree:
I discovered Stoners when it was given as a handout at a our Skyline Drive cruise!
By FAR the best Ive used.
Problem is, the only place I can find it is inmail order catalogs :cuss
