Trans leak fix..easy as pie.
Old Jan 26, 2003 | 05:06 PM
69mako's Avatar
69mako
Default Trans leak fix..easy as pie.
What I thought was a leaking bad O-ring at the speed sensor on my trans was a bad speed sensor that was leaking :eek: :eek:
A run up to NAPA Auto parts and $35.00 later the leak was fixed :thumbs:
Empty the trans of fluid and then use a 14 MM socket and a med length wrench, pull the bolt out holding the clamp on top of the speed sensor, pull out the sensor put in the new one and your finished :yesnod: :yesnod:
Larry :steering:
Old Jan 26, 2003 | 05:33 PM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Default Re: Trans leak fix..easy as pie. (69mako)
Nah, it was the O-Ring, the new sensor just happened to come with one :p:
That was a piece of cake compared to the shifter install! But it was a great day :cheers:
So, no more leaks for Larry? :blueangel:
Old Jan 26, 2003 | 08:26 PM
VQT88Vette's Avatar
VQT88Vette
You could use permatex and spread aroung the O-Ringtore-seal the leak since the sensor still works.:) I don't want to pay $35 for an o-ring.
Old Jan 26, 2003 | 09:55 PM
Corvette0096's Avatar
Corvette0096
:cheers:
Old Jan 27, 2003 | 06:14 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: Trans leak fix..easy as pie. (corvette0096)
:cheers:
Jesus Rich, do you say anything at all. I'm starting to think you're like Silent Bob....... :jester Now I know how you're cruising to 10k.... just as bad as Noggles :conehead
Old Jan 27, 2003 | 08:41 AM
Corvette0096
Default Re: Trans leak fix..easy as pie. (Jeffvette)
:cheers:
Old Jan 27, 2003 | 01:20 PM
ShawnZR-1's Avatar
ShawnZR-1
Default Re: Trans leak fix..easy as pie. (VQT88Vette)
No, I was kidding, the sensor was leaking out through the electrical connection. The O-Ring was fine. I was yanking Larry's chain ;)
Old Jan 27, 2003 | 03:47 PM
Joeyvette's Avatar
Joeyvette
I had the same problem back in October. I also bought a sensor from Napa and put it in; oil leak cured :cheers: Well, my speedometer was going crazy and my tranny was slipping like hell :reddevil I took the Napa part out and took it back since it was a POS. I hit the Chevy dealer and bought the original part for 6 dollars more and it worked perfectly :cool: I'm glad yours worked for you, maybe I got a bad part from Napa.
To Trans leak fix..easy as pie.
