375HP on a Stock C4
Old Jan 27, 2003 | 03:43 AM
Light84vette's Avatar
Light84vette
Default 375HP on a Stock C4
Will my 84 handle the power, its an auto and I think I would make 375HP at least at the min, with my setup. I'm just not ready to change the drivetrain just yet, but I want some fun with my car, its only 205HP but its okay BUT its kinda getting boring. :bb
Old Jan 27, 2003 | 04:04 AM
No Go's Avatar
No Go
Default Re: 375HP on a Stock C4 (Light84vette)
Haven't you asked this question already?
Old Jan 27, 2003 | 05:50 PM
Light84vette
Default Re: 375HP on a Stock C4 (No Go)
Yeah, but I only got a reply by one person, which was Vader, Thanks Vader :thumbs: But I want more opinions from more people. ;)
Old Jan 27, 2003 | 06:14 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
you will be putting a tranny in the car for sure! :yesnod: i am on my third! :eek: good luck! :cheers:
Old Jan 27, 2003 | 07:50 PM
Light84vette
Default Re: 375HP on a Stock C4 (yoslambo1@cs.com)
But your making 450+HP I'm only shooting for 375HP at the Fly, are you saying the tranny wont even last to that point? :confused:
Old Jan 27, 2003 | 08:02 PM
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
375 at the fly...you should be fine. :yesnod: :cheers:
Old Jan 27, 2003 | 08:15 PM
Light84vette
Default Re: 375HP on a Stock C4 (Zora)
What about the Rear Dana 36?
Old Jan 27, 2003 | 08:20 PM
NUckINg FuTS's Avatar
NUckINg FuTS
They say a D36 will take up to 400 hp at the fly. That's with street tires of course ;)
Old Jan 27, 2003 | 08:49 PM
atotalnincompoop's Avatar
atotalnincompoop
i'm making over 400 and haven't had a problem yet :yesnod:
of course i can't get any traction either, who knows if i actually hooked up :cheers:
Old Jan 27, 2003 | 09:39 PM
Light84vette
Default Re: 375HP on a Stock C4 (atotalnincompoop)
I cant get any traction right now, I wonder hoe it would be like when I double the power.
atotalnincompoop, when exactly do you loose traction? When you start off, or when you are rolling say 25mph and you open the throttle all the way? or is it when the transmission shifts gears?
Old Jan 27, 2003 | 09:48 PM
NUckINg FuTS
That's because 4+3 = D44 :yesnod:
[Modified by NUckINg FuTS, 8:50 PM 1/27/2003]
Old Jan 27, 2003 | 10:02 PM
Light84vette
Default Re: 375HP on a Stock C4 (NUckINg FuTS)
It would seem to me that it would make more sense if the put a Dana 44 in the autos than the Sticks. Auto's almost double TQ before they lock up so why would they put in a weaker Rear end?
Are you guys saying that then 400HP will break my stock drivetrain?
Old Jan 27, 2003 | 10:23 PM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
The need for the stronger diff in the stick is due to the torque slap, or sudden application of torque when you side-step the clutch. Autos will not (at stock setups) put the same amount of power to wheels when the car is first starting off the line.
Old Jan 27, 2003 | 10:54 PM
yoslambo1@cs.com
no im just saying that if your transmission is origional its bound to go. :yesnod: i already have gone 1 season with the 383 & have had no problems....however the last time i had the transmission rebuilt i had xtra clutches installed & put a transgo shift kit in with a 2800 stall converter......oh yeah i also put in a big transmission cooler. so far soo good! :cheers:
Old Jan 27, 2003 | 11:05 PM
Zora's Avatar
Zora
Cruise-In I Veteran
A Vette Buddy of mine has had 3 Dana 36s(3.54 now has 3.73)...he is around 290hp at the wheels. Stock gears 3.07 you might be Ok... Some of you are just Lucky....it will be a chance you will have too take. But a Dana 44 will take care of the problem. :cheers:
Old Jan 27, 2003 | 11:42 PM
Light84vette
SO this means that if I do this 375HP upgrade I will have to baby it just at the starting point, after I start roling like at 10-15mph I could slam the gas right? Or I'm outta luck there to?
Old Jan 28, 2003 | 10:15 AM
MrNuke's Avatar
MrNuke
You got it right... Just make sure you do not put drags or stickier than street tires on your car and you should be fine... At least that's what I'm hopeing for. :lol:
To 375HP on a Stock C4
Old Jan 28, 2003 | 11:49 AM
DINO's Avatar
DINO
Cruise-In III Veteran
Cruise-In IV Veteran
I went to Cruise-In V with Vetteweiser
Default Re: 375HP on a Stock C4 (MrNuke)
Light84 what exactly are you doing to the car to get such a jump in Horsepower... :confused:
Old Jan 28, 2003 | 07:01 PM
Light84vette
Default Re: 375HP on a Stock C4 (DINO)
None smog aluminum Heads, 200cc intake volume and new headers, take off the Cat and smog pump, change the intake for a higher flowing one, and then use two 2bbl TBI's with of course a new fuel pump. Oh yeah running 9.6 to 1 compression------Edelbrock did something like this but at 9.5 to 1 and a carb and got 420HP out of SB 350CID. SO I dont expect to make 420 so I will aim at 375HP at the Fly. :yesnod:
Old Jan 29, 2003 | 02:30 PM
DINO's Avatar
DINO
Very cool good luck :thumbs: lets us know how it goes
