How many different Mitsubishi Opti sensors are there? For instance, are any of the sensors from the B body or F body LT1 cars compatible to swap into Opti distributors for any of the Corvette model years?
Early, non vented, spline drive in the early cars
Used in model years up to and including 94 in Corvette.
Late, vented, pin drive used in 95+ Corvette. I believe the full size cars got the pin drive in 94.
Late opti preferred for durability with the venting. I couldn’t tell you if the Mitsu optical sensor between late/early is the same or if there were changes to it.
optisparksolutions@gmail.com
This is the old optidoctors email. I don't know if he still answers questions. He would know 100% accurate answer. His name is Brad. Dan
