84 THROTTLEBODY
Old Jan 27, 2003 | 02:05 PM
ink4lfe's Avatar
ink4lfe
Default 84 THROTTLEBODY
WHAT SIZE IS IT AND HOW MUCH CAN IT BE BORED OUT TO AND WHAT IS THE BIGGEST INJECTOR I CAN PUT IN IT. :cheers: :withstupid:
Old Jan 28, 2003 | 11:46 AM
Phobos84's Avatar
Phobos84
Default Re: 84 THROTTLEBODY (ink4lfe)
If you are talking about the crossfire they are about 550 cfm together. I have mine bored out to 2 inches. (Factory is 1 11/16) after boring it will flow about 660 cfm. As far as injectors the ones from Turbo City are the biggest and best I have ever found and they are 68 lb cop car injectors. I think some place made bigger but not at this value. I think they are arround $120. One problem. It is pointless to put bored out throttle bodies on a stock intake. The intake can only flow about 550 cfm. So you need to get an X-ram or port your stock intake.
Old Jan 29, 2003 | 05:04 AM
JoBy's Avatar
JoBy
Talk to Dan Plett.
http://www.alltel.net/~plett/Crossfire.htm
This is his work.
Comparison between the OEM bore (left) and a sleeved housing with a bore of 2.130" (right)
Stock (1.812") TB, two injector tower gaskets @13.6" - 286 CFM (each) total, 572 CFM together.
2" TB, two injector tower gaskets @13.6" - 333 CFM (each) total, 666 CFM together.
2.130" TB, two injector tower gaskets @13.6" - 379CFM (each) total, 758 CFM together.
Old Jan 29, 2003 | 10:28 AM
Phobos84's Avatar
Phobos84
Default Re: 84 THROTTLEBODY (JoBy)
Dan does great work. I didn't know he started sleeving them and boaring out to 2.130. He did my throttle bodies a few years back. Did a great job.
Old Jan 29, 2003 | 02:53 PM
ink4lfe's Avatar
ink4lfe
THANKS JONUS FOR THAT WEB ADDRESS. I HAVE AN INTAKE AND THE TB ON THERE WAY. I'VE ALREADY DONE PRETTY MUCH ALL I CAN THAT MOTOR, I WANT MORE POWER AND I THOUGHT THAT WOULD BE THE WAY TO GO. THANKS :chevy :auto:
To 84 THROTTLEBODY
