85 oxygen sensor help
Old Feb 17, 2024 | 11:33 AM
sturmmorser2000's Avatar
sturmmorser2000
Default 85 oxygen sensor help
Is the wire going to the oxygen sensor supposed to have enough voltage to light up a test light when its running?
Old Feb 17, 2024 | 09:11 PM
Tunedport90's Avatar
Tunedport90
No , its feeding a mv signal to the ecm is fluxing when the o2 is working at 5-600f exhaust temperature.
Old Feb 17, 2024 | 11:38 PM
sturmmorser2000
So after driving it awhile to get it hot then when i check it will it light up?
Old Feb 18, 2024 | 12:16 AM
Tunedport90
i don’t understand what you mean light up ?
Old Feb 18, 2024 | 02:14 AM
sturmmorser's Avatar
sturmmorser
6th Gear
I put a test light on the wire going to the sensor
Old Feb 18, 2024 | 07:13 AM
ULTM8Z's Avatar
ULTM8Z
It's not going to put out enough voltage and current to light up a test light.
If you dont have a scanner...
You'd be better off hooking up a voltmeter (if its fast enough to keep up with the fluctuations since the sensor is continuously bouncing between about .1 and .9V)
Old Feb 18, 2024 | 10:57 AM
sturmmorser2000
With my multimeter i measured the voltage from the wire going to the sensor with the ignition on engine not running. I measured 9.5 volts does this mean power from the ecm is good?
Old Feb 18, 2024 | 11:18 AM
Tunedport90
Wow, you need to understand the o2 is like a battery giving off milivolts to the ecm. What issues do you even have?
Old Feb 18, 2024 | 11:22 AM
sturmmorser2000
code 13 trying to determine if its the ecm or sensor
Old Feb 18, 2024 | 11:23 AM
sturmmorser2000
I put my meter on the diode setting it reads off in millivolts it said 656 on the ecm wire it that good?
Old Feb 18, 2024 | 01:42 PM
ULTM8Z's Avatar
ULTM8Z
Put the meter on the O2 sensor wire while the engine is running and at full operating temp. If the voltage isn't bouncing between 100 and 900 mV, likely a bad sensor.
The sensor doesn't depend on the ECM to run itself. It generates its own voltage output that the ECM reads.
To 85 oxygen sensor help
