Help with ZF6 swap
Old Feb 20, 2024 | 08:47 PM
Dragon7u's Avatar
Dragon7u
Default Help with ZF6 swap
Hello everyone,
As the title says I am doing an engine swap and 700r4 to zf6 swap. I have been following this guide. https://www.corvetteforum.com/forums...-zf6-swap.html but I am running into some difficulty with the interior. Has anybody done this swap on an earlier c4? Then parts I'm having trouble with are the installation of the pedals (I have a 86 parts car with the doug nash I took the brake and clutch out of), and the cutting of the trans tunnel. Any and all advice is appreciated. Thank you.
Old Feb 20, 2024 | 09:12 PM
ChumpVette's Avatar
ChumpVette
What is the issue you are having trying to get the pedals in?
Old Feb 21, 2024 | 02:59 PM
MrBigDee's Avatar
MrBigDee
I did a ZF swap on my 86. Installing the pedals was a real pain in the ***
Old Feb 24, 2024 | 04:54 PM
J.Abbott's Avatar
J.Abbott
I don't remember having any issues installing the pedals. What issue are you running into? I have done two auto's to ZF6 spd cars. On both I used the trans tunnel section from a ZF car. On both I also used the later pedal since it was a little smaller than the 4+3 pedal. I prob swapped the brake pedal as well since everything matches. The last one I did though was in 2003. I still own one of them though so I can go back and look what I did. I may even have and extra set of pedals.
To Help with ZF6 swap
