Fuel pump line removal
Old Feb 26, 2024 | 11:39 AM
CorvetteRules's Avatar
CorvetteRules
Default Fuel pump line removal
Trying to replace the fuel pump on my 95 but having issue with removal of fuel lines. Got the bottom left off but I cant get top right off. Not enough room to get my big hands in a position to pull it off. I can get some rotation using pinch nose plyers but cant get to any leverage to do anything else. Any hints ??
Old Feb 26, 2024 | 12:24 PM
Whaleman's Avatar
Whaleman
In my experience with that line you will NEVER pull it off. It has to be pushed off. I was able to get a long needle nose on each side of the end and figured out how to brace it and push it off. Pulling is like a Japanese finger trap. Dan
Old Feb 26, 2024 | 02:47 PM
CorvetteRules
Your tip was perfect! Pushing with needle nose was the answer. That line was really frustrating me. New pump installed and all buttoned back up. I had looked at a couple of YouTubes but none had any tips on removing fuel lines. Playing with that one line took longer than pulling and installing the new pump. I did end up reusing the sock, it was in great shape and the Delph replacement didn't come with a new one. Again, many thanks Whaleman !!!
Old Feb 26, 2024 | 06:05 PM
Whaleman's Avatar
Whaleman
You are very welcome!!! I am so glad that tip worked for you also. Dan
To Fuel pump line removal
