AC Compressor Turns off when AC is on.
Old Feb 28, 2024 | 08:21 PM
realgone95's Avatar
realgone95
2nd Gear
Default AC Compressor Turns off when AC is on.
My 96 base model corvette has a strange issue. The compressor is always running unless I turn on the ac. Which it then turns off. I have tried jumping the low pressure switch to turn it on, which works when the ac is off but if it is on then the compressor will not engage.
Old Feb 29, 2024 | 06:16 PM
64Scout's Avatar
64Scout
Your ac clutch is engaged when the ac is off? Or you just see the pulley turning?
Old Mar 1, 2024 | 12:44 AM
realgone95's Avatar
realgone95
2nd Gear
Yes the clutch is always engaged unless I turn the AC on at which point the clutch disengages and the compressor stops spinning.
Old Mar 1, 2024 | 10:18 AM
64Scout's Avatar
64Scout
Thats odd, because I'm pretty sure the clutch power goes through the low pressure switch and the high pressure switch. I was thinking that maybe the compressor is locked up and when the clutch is engaged it stops the pulley.
To AC Compressor Turns off when AC is on.
