Years ago my 84 did the same thing when I stopped in a parking lot. I cut a wire going to the motor and I never fixed it. It's a "one of these days" kinda projects. I cut that wire around 20 years ago 🤣
Open the hatch and remove the trim that surrounds the roof stowage latch. There is a relay with 6 wires, usually with a white case. Unplug the connection with the gray, green, and I think white wires. These are to the antenna.
You can also remove the CTSY fuse, but a lot of other stuff stops working as well as the antenna. However, removing the fuse will stop the motor until you have time to unplug the relay.
Thank you sooo much, maybe I can still spare my motor (this has been going on for a while now). Much appreciated
