Temp check at 60 degrees
Old Mar 8, 2024 | 12:29 PM
BET VETTE's Avatar
BET VETTE
Default Temp check at 60 degrees
I did and hour drive then I park and let it idle for ten minutes …. Gauge read
ing
Old Mar 8, 2024 | 01:47 PM
CorvetteRules's Avatar
CorvetteRules
Is there a question?
Old Mar 8, 2024 | 03:04 PM
BET VETTE's Avatar
BET VETTE
Sorry, I should’ve been more clear. I’m just showing my average running temperature at 60 degrees. I hear many members talking about engine temperature so I thought I’d just share mine.
Old Mar 10, 2024 | 11:29 AM
AmoriFati's Avatar
AmoriFati
you mean a 160 degrees? in your 93 Corvette? That gauge runs off of the sensor in the head I believe. What does the digital gauge say for temp?
Old Mar 10, 2024 | 11:36 AM
BET VETTE's Avatar
BET VETTE
The outside temperature for that day was 60 degrees fahrenheit
Old Mar 10, 2024 | 11:46 AM
AmoriFati's Avatar
AmoriFati
Okay, not sure what you are trying to find out, but, if its 60 outside, and after 10 minutes the gauge reads X? What is your thermostat, fan settings, etc. And, compare it to the digital gauge too.
My 93 is usually at the 20 degrees higher than my 160 degree thermostat, but close to my 185 degree fan settings.
Old Mar 10, 2024 | 12:28 PM
BET VETTE's Avatar
BET VETTE
I was just showing others what my temperature (gauges) is reading after a hour drive and then I parked with the engine idling for ten minutes . Nothing special but just maybe someone wants to make a comparison
To Temp check at 60 degrees
