Fuel injectors
Old Mar 9, 2024 | 06:35 PM
Pdiou74's Avatar
Pdiou74
Default Fuel injectors
Hey All,
Ive been working on a 93. Last time she was registered was 2012. runs rough when I start it up. The idle revs up and down and eventually stalls out. I checked the ohms on the fuel injectors and they are all reading in the mis 8's cold. From some reading ive done said should be much more. Advice? what should I do first?
Thanks in advance.
Old Mar 9, 2024 | 07:14 PM
ULTM8Z's Avatar
ULTM8Z
Is it the same fuel in the tank since 2012?
Old Mar 9, 2024 | 07:20 PM
AmoriFati's Avatar
AmoriFati
If the idle is going up and down, check the IAC. Also, while this is happening turn ac on to see if it changes. If it does, IAC is getting commands from ECM. If not, might be IAC. THey do go bad and will not throw a code.
Old Mar 9, 2024 | 08:16 PM
Pdiou74's Avatar
Pdiou74
no, it was almost empty so I added fres gas and an additive to the tank
Old Mar 9, 2024 | 08:17 PM
Pdiou74's Avatar
Pdiou74
I'll give that a try in the am, were in the middle of a jersey monsoon:/
Old Mar 9, 2024 | 11:59 PM
MaxLean's Avatar
MaxLean
That resistance seems low. Typical injector resistance for the stock Multec fuel injectors should be 12-14 ohms.
Old Mar 12, 2024 | 08:40 AM
signify's Avatar
signify
Do you have the service manual? Two books of repair and troubleshooting. If not pm me for i have a 93 and can reference for you.
Old Mar 12, 2024 | 09:28 AM
Riley93C4's Avatar
Riley93C4
Correct, if you ohm those injectors they should be between 12-14. That is what my 93 injectors read.
Old Mar 12, 2024 | 03:37 PM
Pdiou74's Avatar
Pdiou74
Srry, what's pm:/? Im online now trying to find a pdf download for the gm 93 service manual. Im reassembling the steering column as we speak. hoping that manual can give me some help.
Old Mar 17, 2024 | 12:26 AM
ULTM8Z's Avatar
ULTM8Z
Srry, what's pm
PM = Private Message
To Fuel injectors
