84-89 telescopic steering column ???
Old Mar 10, 2024 | 01:17 PM
Bill Chase's Avatar
Bill Chase
Default 84-89 telescopic steering column ???
Have any of you ever retrofitted the tilt column from an early c4 to a 91-96 c4?
Old Mar 11, 2024 | 09:28 AM
WVZR-1's Avatar
WVZR-1
I know of no one personally that's been successful or even attempted. It's certainly been mentioned before.
The mast-jacket is very different and the addition of SIR with '90+ would make a direct fit impossible. If a person didn't mind loosing SIR and had 1 of each 'side by side' you could investigate swapping the shrouds and the upper column components,
Old Mar 11, 2024 | 10:22 AM
Bill Chase's Avatar
Bill Chase
Yeah, thats. Pretty much what I was planning to do, some insight from those that have been there and done that would obviously help a lot. Good news is most gm Saginaw columns from 70-to the early 90's are very very similar in design, a lot of parts interchange between models.
Looks like I have to be the test guinea pig if I want it. It is interesting that the 84-89 cars telescopic columns do not tend to get loose pivot pins like the 90-96 cars do. At least you don't hear about problems as much for the early cars. Thank you for the response.
Old Mar 11, 2024 | 11:09 PM
-=Jeff=-'s Avatar
-=Jeff=-
Yes I have a 87 column in my 1990z. I not longer have an airbag.
what specifics are you looking for?
Old Mar 12, 2024 | 10:03 AM
WVZR-1's Avatar
WVZR-1
I forgot about yours!
Old Mar 12, 2024 | 11:34 AM
Bill Chase's Avatar
Bill Chase
Specifics,
1. wiring
2. Any mechanical differences that must be addressed
Obviously I will have the donor column and my cars column side by side on a bench, any and all insight, road blocks, specific additional parts I need prior to doing the swap, any.. "if I knew then what I know now I would have done that, or not done this etc. thanks man, really appreciate any insights you have on the swap.
To 84-89 telescopic steering column ???
