MPH LCD lit Blank
Old Mar 11, 2024 | 10:17 PM
Pdiou74's Avatar
Pdiou74
Default MPH LCD lit Blank
So im still working out the kinks on the 93 the MPH LCD is lit but blank. The column is not back together, the upper shroud I needed just came in the mail, this is next, been starting it with a plunger switch to the starter solenoid and battery. Could this be why there is no data on the lcd? Any of these wires that need to be connected with the column control the MPH data? The Fuel injectors are reading in the mid 8'sOHMS ive read they should be in the 12-13 range, I Hooked a gauge to the schrater valve and it registers zero but the car starts right up and runs ok(not great by any means but way better than when I first got it started). I got it on the cheap and the last time it was registered was 2010 I think a few days ago I said 12, my mistake. Every time I start it and let it run it sounds a little better each time. I connected and obd1 plug to it and the codes came Back 43(knock circuit) and 64(OB sensor) does the code 43 have todo with the option spark? Any help is always appreciated. Thanks
Old Mar 12, 2024 | 07:31 AM
Incorvettei's Avatar
Incorvettei
That LCD panel is well known for bad solder joints. I would start by looking at them
Old Mar 12, 2024 | 01:49 PM
Pdiou74's Avatar
Pdiou74
I seeing there are aftermarket analog dash replacements. would that be a big deal to replace?
Old Mar 12, 2024 | 07:59 PM
Bill Chase's Avatar
Bill Chase
Battee Corvette can fix your cluster. They have parts in stock. Odds are half the places advertising the ability to restore your cluster are sending to them and marking up the price.
You can also find used clusters on eBay. The ccm stores mileage, not the cluster, so replacement with a year that is compatible isn't a big deal for the 90-96 cars.
Old Mar 12, 2024 | 08:00 PM
Bill Chase's Avatar
Bill Chase
https://batee.com/pages/contact-us
To MPH LCD lit Blank
