Assembling a friends 95. Tried to pull the steering pump and noticed some of the bolts are missing. Been driving it this way for 9 months.
B4 I pull it, would someone tell me the bolt sizes. Heads are 10mm, and looks like I'm missing one of the longer bolts and one or two of the shorter.
Easy job if I have all the bolts.
best i can tell, the only bolts i see are associated with the PS pump mounting bracket. two sizes -- M8-1.25 X 25 , Gr 9.8 (p/n 11508106) and M8-1.25 X 35 Gr 10.9 (p/n 11507034), seems there's a special bolt that holds the pulley to the pump - sems hex w/fl washer - M6.3-1.81 X 20 (p/n 12337828). old data - assuming it's correct. hope this helps....
I just replaced both the pulley and the pump, there is no bolt to hold the pulley on it's pressed on using the standard tool. I didn't take measurements of the bolts before I put everything back together, but if I'm remembering correctly there were two longer bolts and two shorter bolts, so your sizes there seem right.
When you receive and confirm it might be good to post back the measured specifications. I don't know but maybe if you post a link to the eBay purchase maybe someone can comment on your buy?
