I recently upgraded my intake (BigMouth base, AS&M runners, ported plenum), and added 1.6 roller rockers while I was in there. Deleted EGR and AIR pump plumbing.
Set fuel pressure to 48psi, and base timing to 8 degrees.
I now have a noticeable misfire in the 1600-2000 rpm range. Plugs and wires are AC Delco and new last year. I guess maybe a wire could not be seated properly, I plan on double checking that.
It also seems to idle a bit higher cold than it used to (takes longer to settle at the 600rpm range). TPS is still showing .56v.
