Bad miss
Old Mar 16, 2024 | 04:26 PM
Kim Neubert's Avatar
Kim Neubert
Default Bad miss
1987 bone stock. Drove in, in the rain, running great. Next day, starts runs really bad, missing badly, black smoke. Waited a while, then, no start. Next day start, runs bad. Plugs less than 500 miles. I put in new cap, rotor and module.40 PSI fuel pressure. Starts okay missing bad at idle, will rev pretty well. I noticed I have a hole in the right pre cat, but I think it's an old hole. Any idea why it is running so bad.
Old Mar 16, 2024 | 04:39 PM
s carter's Avatar
s carter
Since you said you were in the rain, either pull a Fuel sample from fuel rail or Syphon/draw it from the bottom of tank.
Get sample into a clean clear jar if you have water in it you will see it, they separate very quickly.
Now the usual how would it get in, the drain in the filler area gets clogged and drowns the cap.
Old Mar 17, 2024 | 08:08 AM
LiveWire1's Avatar
LiveWire1
Use an infrared temperature gun to find your miss. Point it at the exhaust ports, where they meet the exhaust manifold. They'll all be hot, except the misfiring cylinder, which will have a cool exhaust port.
Old Mar 17, 2024 | 02:58 PM
Kim Neubert
Old Mar 17, 2024 | 02:59 PM
Kim Neubert
Thanks. I also should have mentioned, no codes.
To Bad miss
