Crazy wobble or shake in the front end
Old Mar 20, 2024 | 12:27 PM
Mitchell2213's Avatar
Mitchell2213
Default Crazy wobble or shake in the front end
So I have an 87 corvette and at around 35-40 mph there is a wobble or shake in the front end. If I break even in the slightest it will go away, release the break it will do it again, also if I accelerate over that 40-45 mph threshold it will also not be there.
I was thinking it could be a tires but they look fine maybe a warped rotor but it doesn’t do it when I break. I have a rack and pinion leak but there is fluid in there right now. Any ideas?
Old Mar 20, 2024 | 01:06 PM
yakmastermax's Avatar
yakmastermax
Dead tie rod ends?
Old Mar 20, 2024 | 06:14 PM
Yonker's Avatar
Yonker
Check your ball joints, wheel bearings, steering linkages, and lug nuts, and lastly check the balance of your tires.
To Crazy wobble or shake in the front end
