Can a weep hole have a negative impact on thermostats
One 1/16" hole at the top of the T-stat is all you really need. I've seen some T-stats come with a tiny vent hole with a rubber nib pushed thru the hole, so as to act as a vent valve of some sort. Where air can flow out but not coolant. I assume this was done to reduced the amount of coolant bypassing the T-stat.
The following 2 users liked this post by arbee:
VikingTrad3r (04-01-2024),
Whaleman (04-01-2024)
.Remember that thermostats regulate Minimum coolant temperature.
With holes the thermostat will become fully-closed, or begin to open at a higher ambient temperature than it will without the holes. This will affect heater output and operating temperature at idle and low loads.
If the freezer is big enough, and you put the oven in it with the door open, the ice cubes won't melt as quickly. The oven can't produce as much heat as the cold of its surroundings suck up. Engines in cold ambients at idle are the same deal. The block radiates heat. The heater core radiates heat. With holes in the thermostat, the radiator is now radiating heat.
64Scout (04-02-2024)
I saw about 2 degree F difference at about 27 degrees F ambient temp at most... hardly what I'd call any meaningful difference and is well within the error of the ECT sensor... this is worrying about things not worth worrying about....
Last edited by 84 4+3; 04-04-2024 at 09:00 AM. Reason: I'm retarded and left it alone for all to see.
BWPJS (04-04-2024)
The thought that a thermostat with holes needs a higher ambient temperature to start opening vs a thermostat without holes is sheer nonsense. The opening and closing is controlled by the expansion and contraction of the wax in the cylinder. This wax does not know whether the stat has no holes, small holes or a hole the size of your thumb. A large hole will allow more fluid to flow before opening and thus yes, extend the warm up temperature to some degree(this is carrying the scenario to an exaggerated degree and not what the OP asked). However, once the fluid temperature approaches the set point, the opening will start, holes or no holes.
The following 3 users liked this post by arbee:
Not sure why you would want to be so publicly self deprecating but that's your choice I guess. As far as the issue at hand, my comment had nothing to do with you.. If it had been in reference to you, I would have quoted you rather than make an open post. You know, like you quoted my comment.. Lack of reading comprehension strikes again.
I'd rather admit I'm the fool or make a mistake than have people blindly read and believe what I say is right when it isn't. Without proper explanation on my post, it reads wrong for the exact reasons you've stated in your post. Sorry.
never admit your a fool, just learn from it and move on.
I always thought the small hole in a thermostat is to release possible air pocket
I am one of two who mentioned ambient temperature directly and it definitely read like it was in reference to quite a bit of what I had said but... I am wrong again. And yes... I misread. My apologies sir.
84 4+3 (04-04-2024)
