1986 C4 with engine problems 0 psi Oil pressure
Old Apr 5, 2024 | 05:43 PM
Kyle Druktens's Avatar
Kyle Druktens
Default 1986 C4 with engine problems 0 psi Oil pressure
Hello I have a 1986 c4 corvette with the small block 350 bored out. It was my dads and before he got it someone bored it out also mentioned he bent a push rod and replaced it but doesnt know how good of a job it was. The car rn has two knocks in the motor, one may be a push rod and the other idk what it is. The car starts fine and drives fine when easy on the throttle, with oil pressure at 40 psi or normal psi but when it gets warm it starts to drop, It will get to 0 psi at idle and stay there untill I get back on it and get 20 psi under load. Just replaced the two Oil pressure switch/sensor and got the same readings so I belive its not that. I feel like when its cooler it gets more power and when warm/hot has lack of power but makes sence bc the oil pressure idrk. When I get on it feels like a huge lack of power, but if I ease on to it i feel more power it hard to explain. Now Im not sure if my motor is going out or theres a possible fix, considered swaping the engine.
Anything helps Thanks
Video of the knock in motor
Main knock when warm at 0 psi
Video of cold start with old Oil pressure gauge switch/sensor
Dash showing 48-50 psi when cold
Old Apr 5, 2024 | 06:44 PM
solar88's Avatar
solar88
When it dropped to zero did the engine make a lot of valve noise ? If not maybe your gauge is bad ? I have a hard time believing that if your oil pressure was at zero for as long as you mentioned the engine wouldn’t make a bunch of noise or have started to seize. I know you said you replaced the sending unit but it might be faulty, or the sensor might not be making proper ground. I would put an external oil pressure gauge on it just to see if the readings are what you saw on the dash gauge and go from there.
Old Apr 5, 2024 | 08:18 PM
Kyle Druktens
Thanks man, when it dropped to zero I dont belive it was making valve nosies, I peeped at the valves and they seemed normal and wet.
I'm working on it at my school that I graduated from, they unfortunately didnt have the oil pressure gauge. I'll go ahead and buy that and try it out on monday hopefully.
Old Apr 5, 2024 | 08:27 PM
AZSP33D's Avatar
AZSP33D
When bearing clearances are increasing due to excessive wear, the oil pressure drops. But not to zero.
what metal bits or sparkles are in the oil filter?
one distinct quality of rod knock is that it is louder when theres no load on the engine, compared to higher loads.
Old Apr 5, 2024 | 09:27 PM
Kyle Druktens
-I haven’t checked the oil filter to see if there’s anything
-It does get louder when no load on the engine, when on load harder to hear.
Old Apr 5, 2024 | 10:14 PM
AZSP33D's Avatar
AZSP33D
Time for a rebuild or another engine. Cut the filter open to confirm if you want.
Old Apr 9, 2024 | 07:45 PM
Kyle Druktens
So I did the oil pressure test with a gauge and it was showing normal psi, even when warm/hot.
Cold start psi and when warm
What could casue my new oil pressure gauge and switch/sensor to read 0 psi? Possibly a ground when it gets hot?
Now Im wondering what that knocking is? Im going to remove my filter to see if I can find anything next week.
To 1986 C4 with engine problems 0 psi Oil pressure
