Help, rear end=funny
Old Jan 29, 2003 | 05:51 PM
TerryD's Avatar
TerryD
Default Help, rear end=funny
On my 96 CE 4spd with Dana 36, 3.07 gears, I get an on gas/off gas clunk from rear diff and the body seems to yaw to the left slightly under hard roll-on accelaration. Is this from a worn differential, worn u-joints, a combo of both or something else?? How long do u-joints last anyway Anyone know any good shops in central Jersey or S. New York? I'd like to step up to a
I recently changed bilsteins and brakes & would like to step up to a 3.54. I've got 'bout 85000, much highway, miles on her. :steering: thanks for the help
Old Jan 29, 2003 | 06:08 PM
1991Z07's Avatar
1991Z07
Default Re: Help, rear end=funny (TerryD)
Check the bearings (mine were shot and exhibited this same symptom), the universal joints, the rear-toe tie-rod ends...anything that can (and will) wear.
Good luck...
Old Jan 29, 2003 | 07:00 PM
vader86's Avatar
vader86
If youre getting a consistent clank, shimmy, or similar noise during driving then its the bearings.
If youre just getting it when you hit the accelerator, it sounds like the U-joints are bad. Which is a little abnormal, your U-joints shouldnt have worn out so soon, unless you do alot of racing. Mine lasted 130K.
Old Jan 29, 2003 | 10:12 PM
TerryD's Avatar
TerryD
Default Re: Help, rear end=funny (vader86)
looks like big money for the kid here, I'd rather have a pro handle this one :thumbs:
To Help, rear end=funny
