160 thermo? Still Skeptical
In 45-55 degree weather, it still gets up to fan temperature (195) but oil stays in the 170-180 range.
This past summer was the first for me, in having a 160* thermostat with four
.200 diameter holes drilled in the housing lip, as suggested by TPiS...for additional cooling during the summer months. Man, that mod works, and works damn good.
So good in fact, that I haven't even changed it out for a 180* thermostat that I run during the winter months (no drilled holes), which I usually do. The engine is purring so good, I just don't want to change a thing.
I thought I would just leave the 160* thermostat in the motor, and just take the Vette out a few times this winter, when the roads are clear.
Problem has been...the days that have been clear...with no moisture on the roads...seem to have been the coldest. I wasn't counting on that.
Twice, the past three weeks, I've taken my Vette out for a 40 minute runs.
With outside temperatures in the twenties...the only way I could get my engine temperature above 160*, was to go thru the gears a time or two, out on the Interstate, and then enjoy a blast of heat for all of a minute,...before the engine began running below 160*...and cold air coming out of the heat ducts.
What was I thinking? (Probably wishing 'spring' was already here).
I wonder how many other forum members have left their 160* thermostat 'in' for the winter months.
Next year, the 180* is going back in. I don't like pulling gears at 6200 RPM's with 'gloves' on. :D
TerryD: I'd suggest you go for the 180* thermostat with the four .200 holes drilled...if your motor isn't modified, and the 160* (with four .200 holes drilled) thermostat, if you've got your engine modified. Your 'chip' should be programmed accordingly.
If not, you'll continue to find your engine temperatures rising in the summer months...especially in stop 'n go traffic.
No need to be skeptical, Terry...many of us have been, where you are at the moment, on this subject.
I can remember, being stuck in very, very, heavy traffic, coming back from Ocean City, Maryland...about 12 summers ago, (before any mods done)...
and pulling off to the side of the road (about 6 times) to let the engine cool down, from the 240*-245* readings I was getting. All I could visualize was the motor cooking, the aluminum heads warping, and the entire engine locking-up.
That was not a pleasant feeling, and I've been running cooler thermostats ever since.
Don't give it a second thought, Terry...go for the cooler thermostat.
[Modified by UDLUV12, 7:41 PM 1/29/2003]
dlmeyers 90 coupe zf6 3 speed shocks
My car only heats up past 180 if I'm idling for quite awhile. It's good to get that oil hot to drive out moisture too. You'd have most problems with condensation living in cold climates, so you should avoid low temp stats.
All drilling does is keep the engine from reaching its operating temp quickly. IMO, the engine should reach its operating temp as soon as possible and stay there.
Assuming you want your cabin temp at 65 degrees, and you switch from a stock stat to a 160 Undrilled Tstat, you're heating capacity will decrease by 23%. Just turning up the heater fan should easily make up for this.
my stock LT4 still runs at 200+ with a OE thermastat.
Just remember, at full open or fully closed, a 160 stat is a 180 stat is a 195 stat.. they're all the same. Changing the tstat will only affect how your car operates between 160 and 195 degrees, give or take 5 degrees. On a hot summer day with the a/c on, your thermostat rating won't make any difference. Drilling holes will help a little, but will cost you in colder temps.
To make your car run cooler after the thermostat is fully open there are 4 basic ways:
Clean your heat transfer surfaces
Increase surface area (by turning on heater, or upgrading radiator
Increase flow (high flow waterpump, or less restrictive thermostat, etc.)
Get more air across the radiator (drive faster or turn on elec fans sooner)
:steering:
So I still think a 160 stat is ok to run year round and at least my heater runs fine, BUT a 160 stat or any stat with holes drilled in it is not a very good idea for street use in cold weather since the engine will be very slow in warming up and most likely in real cold weather will never get warm, thus poor heater performance.
I think the trick is to lower the temp that your cooling fans come on.
On stock motors, the temp rises to 230 degrees plus, which I think is crazy.
I plan on having the fans come on at 190 degrees and off at 180. This can all be done thru the chip. You can adjust this to whatever is comfortable to you. :cheers:
