1989 corvette burnout
Old Apr 17, 2024 | 11:34 PM
Cameron14733's Avatar
Cameron14733
Default 1989 corvette burnout
I’m struggling to do a burnout in my 1989 corvette while doing a burnout it won’t go past 1900 rpm’s but when I let off the brake it jumps and moves past 1900 rpm’s any thoughts on this ?
Old Apr 18, 2024 | 01:41 AM
Leonidas_'s Avatar
Leonidas_
Try pedal to the metal and then brake the milisecond you feel the tires spinning. Empty flat area ofc
Old Apr 18, 2024 | 02:49 PM
Cameron14733
tried that multiple times loosened up the break while doing one and still woudlnt rise past 1900
Old Apr 18, 2024 | 03:44 PM
tequilaboy's Avatar
tequilaboy
At least you've identified the stall speed.
Old Apr 18, 2024 | 04:07 PM
BET VETTE's Avatar
BET VETTE
Are you saying that when you punch the gas down far the tire’s doesn’t spin
Old Apr 18, 2024 | 08:20 PM
64Scout's Avatar
64Scout
Get the tires wet first. If it still doesn't do it, put a line lock in. If that doesn't work, big block swap it
Old Apr 18, 2024 | 08:22 PM
Cameron14733
it spins but won’t go past 1900 rpm’s which is weird because a month ago I had them burning rubber with smoke flying everywhere.
Old Apr 18, 2024 | 08:23 PM
Cameron14733
[QUOTE=64Scout;1607729342]Get the tires wet first. If it still doesn't do it, put a line lock in. If that doesn't work, big block swap it[/QUOTE
try telling that last part to my wallet
Old Apr 18, 2024 | 09:41 PM
2011KLR's Avatar
2011KLR
Any chance your throttle linkage is sticking and not allowing full throttle?
Old Apr 18, 2024 | 11:15 PM
Cameron14733
honestly yes there is a chance I have a small kink in the line that I have straightened to the best of my ability. How ever i literally put all of my weight on the gas to get it down as far as it would go and nothing changed.
To 1989 corvette burnout
