Ignition switch plug
Old Apr 18, 2024 | 08:16 AM
Kjdad's Avatar
Kjdad
Default Ignition switch plug
Does anyone have a diagram showing the pinout of the black and blue ignition switch connectors? As in, what each wire is...that would be greatly helpful.
Old Apr 18, 2024 | 10:00 AM
WVZR-1's Avatar
WVZR-1
8A10 in the FSM should help you sort what ever you're attempting to do. C1 is Black and C2 is Blue. The correct terminals are ID'd in 8A-10. What are you trying to do?
Old Apr 18, 2024 | 10:08 AM
Kjdad's Avatar
Kjdad
No crank issue. Not seeing any voltage at the VATS relay when cranking. It has a new ignition switch. Does the cranking side of the ignition switch have its own power lead? Or is it one power lead for all ignition switch positions? The cluster and everything powers up..just no juice to the vats relay. Where does the power wire(s) going to the ignition switch get there power from? I see a bunch of red wires near the battery and a power tap with a bunch of red wires connected. I wondering if I have a loose wire or toasted fusable link somewhere?
Old Apr 18, 2024 | 10:21 AM
WVZR-1's Avatar
WVZR-1
What are you calling VATS Relay? Does it CRANK when you jump @ the starter? 8A-10 is entire Power Distribution. Do you have the FSM(Factory/Field Service Manual)?
Old Apr 18, 2024 | 10:25 AM
Kjdad's Avatar
Kjdad
The relay behind the info center. No voltage on any pins in the relay when cranking. I expect to see voltage on one side.
I see 12v at the stater main lug. Nothing at the trigger wire when cranking. Grounds are good.
I have a FSM in the mail.
Old Apr 18, 2024 | 10:33 AM
Kjdad's Avatar
Kjdad
Another symptoms is no power to the gauges when cranking. To me it seems the power coming into the ignition switch in crank position is not happening
Old Apr 18, 2024 | 10:37 AM
WVZR-1's Avatar
WVZR-1
You have paper in the mail or a CD/DVD?
Old Apr 18, 2024 | 10:53 AM
Kjdad's Avatar
Kjdad
Book
Old Apr 18, 2024 | 11:07 AM
Kjdad's Avatar
Kjdad
Maybe i have a break at S203. Wonder where that is in the loom.
Old Apr 18, 2024 | 11:21 AM
WVZR-1's Avatar
WVZR-1
S203 is a considerable 'splice' - do you have power to all fuses end of dash? Stop/HAZ, Brake and all Circuit Breakers? Theft fuse center of dash? Wait until you have your FSM. If by chance you purchased a paper FSM, NOT all FSM would include the EDM(Electrical Diagnostic Manual) if yours doesn't have reach out and I can help you with the EDM and also a very good GM SPO Parts Catalog that would help with parts research for an early car. If you know that it doesn't I could help you sooner.
Old Apr 18, 2024 | 07:39 PM
Kjdad's Avatar
Kjdad
Well that was dumb. The new ignition switch was hung up internally. All fixed for now...I hope..
To Ignition switch plug
