91 C4 L48 Head Removal
Also, what are reasonable priced quality head gaskets and bolts to use. I don't race my car but I rev it, nail it and drive it hard a few seconds at a time,
periodically. Thanks.
I have a high mileage (230K) 91 as well, and I drive it pretty hard, and have had absolutely no issues with these items.
From what I have heard, simply a razorblade scraper works fine. I used one to remove larger pieces of gasket material and such.
The scotchbrite pads cleaned well and created a good seal, but you might want to look into them and assess the potential risks of using them. I likely would not have done so if I had known beforehand.
If you haven't already, I would suggest checking RockAuto. I bought my head gaskets there and saved over $10 each (compared to summit where I bought most of the other supplies).
https://www.summitracing.com/newsand...ion-calculator
Here's the calculator if you want to mess around with it yourself!
Sorry, I do not understand a lot of this but in case this matters for which head gaskets to use, I will mention that the head shop resurfaced the heads, put new valve seals, guides and valve springs. I understand the valve springs are a performance upgrade. The part number for them is 02-1016-16 EPW.
You might start getting into detonation issues...
I think the felpro is 0.041-0.049 compressed.
Might be the low lighting, but it looks "meh", but considering the age.
That stated, it hasn't been running with coolant. Piston tops would be clean if it were; the coolant flashes to steam and cleans them.
Go with the felpro gasket. Everyone likes to talk about going to cometics (MLS) but I would -never- recommend those to someone unless they've had their block decked and their heads made flat. They can be an absolute PITA to get sealed. Felpro's (or stock GM graphite) are way more forgiving in getting everything sealed up.
Stock deck clearance is .025in.
Unfortunately I am not really sure what dome volume they are. It is incredibly difficult to find that information and they changed the pistons several times. Another problem is different people on the forum will tell you different things when it comes to what the stock CR is for the 91. I'm sure its in the service manual somewhere but I don't want to spend my night looking through that.
That being said, assuming the stock compression ratio is 10.25:1, the dome volume SHOULD be 5.9cc. Try it yourself and see if it works. I got this by filling in all the other information, which I know, and solving for dome volume. Assuming a gasket compressed thickness of .041in. If you assume a gasket thickness of .051 the dome volume should be 3.8cc (approximately). I'm not sure what the compressed thickness of the stock gaskets is.
What I would do is not pay so much attention to the numbers themselves, but how the numbers change. If a head gasket changes your compression ratio by .25, it's going to do that regardless of what the numbers actually are. It will still be a difference of .25.
The other commenters are right, the gasket bore should be slightly larger than the cylinder bore.
And the valve springs won't have any affect on what gasket you need.
Hope this helps!
Hope this helps!
