No power at all
Old Apr 18, 2024 | 02:04 PM
ssro's Avatar
ssro
Default No power at all
So i have a c4 1984 and i try to push the gas and it just dies like its being choked, i changed the fuel pump, both fuel filter and twice the one underneath the pasanger, cleaned the gas tank, removed egr and blocked there port under the rear injector, brand new injector, new wires for ingectors, new air filter, check all vacum lines exept the one that goes to the tank, checked the map sensor to see if it was damage but it did not looked damage. And it works a bit better when coled bit it ends up bugging 1 mins later. Its like ether it is being shoot too much fuel and not enough oxygen, or just not enough fuel going to the injectors, i did changed the pasenger fuel filter 3 days ago, ran real good but like after 3 rides it started sying again like theres no fuel being delivered.
Old Apr 18, 2024 | 02:28 PM
2011KLR's Avatar
2011KLR
Blow out the fuel lines maybe there's a bug in there.
(half of that response is real - half of it is a just joking)
Old Apr 18, 2024 | 08:22 PM
64Scout's Avatar
64Scout
Did it sit for a long time before you got it?
Water in the gas?
any codes?
Fuel pressure ok?
To No power at all
