battery short
Old May 2, 2024 | 01:10 PM
choopes's Avatar
choopes
Default battery short
My 93 Coupe looses battery charge after sitting for a spell. I have replaced so many batteries from Interstate. (Exchange since they last less then a year) The Interstate man has told me he can no longer keep swapping them out for me. I bought a battery tender that I use if it is to be parked more then a few days. A short to ground drains the battery. That is my suspicion. This is a intermittent problem. I would go out every few days and crank it. It was fine. Until one day I left the posts connected. I had gone as long as 2 weeks with no problems before. Now after 2 days I've got another dead battery.
I think this is a common problem. I have found posts about work-arounds. Usually involving electrically removing one connector from the battery. One guy installed a knife switch.
What are some common causes, and fixes?
Thank you.
Old May 2, 2024 | 03:46 PM
1Hotrodz's Avatar
1Hotrodz
A friend's C-4 had the same problem. Turned out to be a bad door switch on the center console, keeping the light in the console on.
Old May 2, 2024 | 05:04 PM
jrobin1's Avatar
jrobin1
I have a 93 and had the same issue. The PO had purchased a battery kill switch but never installed it. It turned out to be the antenna wire had touched the tailpipe, burned through the insulation and was shorting the circuit. Translation, it could be almost anything. Check some of the YouTube videos on finding a short to ground in a car. Good Hunting!
Old May 2, 2024 | 05:32 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
This is not the Corvette ownership experience we strive for. Our team would like the opportunity to learn more about the battery on your Coupe and investigate ways we can potentially assist. When you get the chance, please send us an email to socialmedia@gm.com. Be sure to include your Username and Forum name in the subject line, then provide additional details about your experience in the body of the email. We look forward to your contact.
To battery short
