1984 Auto No Spark
Old May 5, 2024 | 06:23 PM
Brown Sugar Builds's Avatar
Brown Sugar Builds
Cruising
Default 1984 Auto No Spark
I've replaced the ignition control module but it didn't fix the no spark issue. I'm also not sure if the injectors are firing. Fuel pump is definitely working if there's any questions you have then I'd love to answer them.
Old May 5, 2024 | 06:48 PM
Brown Sugar Builds
Cruising
I should also add that the yellow and red wires on the ignition coil have 12v when the key is in the on position.
Old May 5, 2024 | 07:52 PM
Brown Sugar Builds
Cruising
Alright I think I found it. There are 5 wires that I found are cut under the car and they all seem to be part of the ignition system. They are pink with black stripe, solid pink, solid blue, tan with black and maybe solid tan.
Old May 6, 2024 | 12:56 AM
typical boomer's Avatar
typical boomer
When I replaced the coil and ICM on my '84 with Pertronix Flame Thrower parts the coil had white, black and red wires, no yellow. Perhaps you have the D3000 coil which has the yellow wire. The D3001 is the correct white wire model for the '84
https://www.summitracing.com/parts/pnx-d3001
https://www.summitracing.com/parts/pnx-d3000
https://www.zip-corvette.com/75-81-p...tion-coil.html
Summit Racing site says they both work but Zip say the yellow wire version is for 75-81 only.
Old May 6, 2024 | 11:29 AM
Brown Sugar Builds
Cruising
Oh interesting. Thank you for that as well.
Old May 16, 2024 | 08:01 PM
Brown Sugar Builds
Cruising
Im still having a no spark issue. I've replaced the distributor, ignition control module, and the ignition coil but still no spark. could it be an ECU issue or a wiring issue and is there anything I can do to test for either?
Old May 17, 2024 | 08:03 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
The BEST thing you can buy is the 84 GM service manual. It has ALL the diagrams and trouble shooting you will need. GL
To 1984 Auto No Spark
