Tuning question, LT1 1993
Old May 10, 2024 | 07:23 PM
AmoriFati's Avatar
AmoriFati
Default Tuning question, LT1 1993
If I change the throttle body size for the 93 LT1, where in TunerCats do I make adjustments for it?
I can reburn and datalog, but just curious if I need to change something. My engine has the 58MM but have split BLMs, might be due to camshaft (236 and 242 at .050 and 110+4 LSA), but I am bringing it down and going to use a OEM throttle body that is 48 mm and a TPIS 52mm to see if it runs better.
Old May 10, 2024 | 07:34 PM
ULTM8Z's Avatar
ULTM8Z
There's no parameter for throttle body size.
You'd just be doing general tuning for the overall engine combination.
Old May 10, 2024 | 07:36 PM
AmoriFati's Avatar
AmoriFati
Thnx. I never did see anything for changing the volume of air per say, other volume per cylinder.
I will datalog and see how it works
To Tuning question, LT1 1993
