Errors data logging 1988 Vette with 1227165_6E.adx
Old May 11, 2024 | 12:22 PM
C4industries's Avatar
C4industries
Default Errors data logging 1988 Vette with 1227165_6E.adx
Hello all, I recently started work on an 88 Vette with a 1227165 ECM and stock ACKY memcal. When I attempt to datalog with TunerProRT I get a blue connected symbol with a constant stream of errors (about 2/second) and no data in the data list in TP. Actually , the data list randomly populates with strange characters like the data is coming through at the wrong baud rate? I'm using a Moates Extreme ALDL cable and the 1227165_6E.adx Any help or ideas here would be much appreciated. Thanks!
Dave
Old May 11, 2024 | 02:24 PM
tequilaboy's Avatar
tequilaboy
The adx file needs to have some pause time inserted in the macro (like 20 ms). Something changed between TunerPro V4 and TunerPro V5 that caused this issue, so older ADS/ADX files that were made during the V4 era will need to be modified.
I've posted a few adx files If you wish to search for them.
Side note: 88 is $32B not $6E, but the datastream is the same except for a few non-essential bytes. I've posted the differences side by side if interested (search).
