Help Identify a LT1 throttle Body
Hey, I have one throttle body I know for sure came off of a 1993 Corvette LT1. But the other is supposedly off of a 1993 also, but its throttle linkage is a bit different. My 1993 Corvette has ASR, so only one cable going to the throttle body, even though I have a 4L60 non electronic. You adjust the TV cable via the ASR.
Is this throttle body from a Camaro? And if you also notice, it doesnt have a IAC hole drilled in it, and this is a TPIS 52mm throttle body they modified an OEM one with..
No IAC passage on TPIS, lower one.
OEM THrottle Body 93 Corvette
TPIS throttle Body
TPIS throttle Body
TPIS throttle Body
TPIS throttle Body
AmoriFati (05-15-2024)
Thnx again. I am going to see if it works on the 1993 Corvette.. Linkage is a bit longer, and I think I can adjust the throttle linkage on the 93 with ASR. I have done the whole ASR, 1/8" drill bit with inch /lbs torque wrench. But, I think I can do the throttle independently.
