1995 C4 differential liquing
Old May 17, 2024 | 07:42 AM
Rory Vega's Avatar
Rory Vega
7th Gear
Default 1995 C4 differential liquing
I do have a 1995 Corvette C4 with a differential leak. Should I use a gasket? Or just a gasket sealant?
Rory
Old May 17, 2024 | 08:23 AM
Whaleman's Avatar
Whaleman
Rory, There are experts here that are able to give you the correct answer. There are numerous places a diff can leak. Maybe a picture or a much better definition of where the leak is would help. With the info you gave nobody could give you an answer. Dan
Old May 17, 2024 | 09:16 AM
Desert Rider's Avatar
Desert Rider
Having gone through this, I can make 3 observations:
1) Make sure the leak is not running back from the pinion seal
2) The cover bolts are threaded into the aluminum case and can strip, requiring a thread repair
3) Do not use a gasket; use the correct Permatex sealant that is compatible with the limited slip additive in the oil and make sure you also smear a little on the bearing blocks.
Old May 19, 2024 | 06:18 AM
Rory Vega's Avatar
Rory Vega
7th Gear
The leak is between the differential housing and the suspension mount (batwing).
I have used the correct Permatex sealant with great care; dismantled all the parts, did it outside the car and applied the correct troque, but for my surprise is leaking again. The good result only lasted one or two days..
Thanks.
To 1995 C4 differential liquing
