Intermittent start and stall - advice needed
Issue
- Intermittent crank no start, but usually starts cold
- Consistent stall appx 5 mins after starting. Car can be restarted after rest/cool down.
- Stall seems to occur at idle/decel (coming to stop light or sign) @ temp = 180-190
- Feathering accel prevents stall
- Car will not restart for 5-10 mins, presumably after the engine cools
- High and sticking idle, intermittent but particularly if I am at around 2500 RPM, it wants to stick around 1300 as I let my foot off. If I tap the accel it will drop to around 800 per my dash tach.
- Voltage @ 15-15.2 on display when car is running (seems a bit high). Current cold voltage is 12.7. (@ batt on multimeter)
- Instrument cluster dims/flickers as car comes to idle/decreases RPM when I am not on accel. Map lights flicker on idle
- During crank/no start ABS and ASR on DIC flicker wildly, otherwise DIC is normal
- No DTC's - C12 in mode 1 and 3xdash in 4 and 9. No H codes
I'm spinning my wheels on diagnostics even with an FSM since these are intermittent and I don't have any codes. If anyone can offer advice or point me toward FSM procedures to follow I would greatly appreciate it.
