Throttle Body Air Foil
But, It was said that the top of the air foil was blocking a majority of the air that goes into the top of the throttle bodys cavity which then allows fresh air to go to valve covers, on LT1s at least. This could cause blow by due to lack of air getting in there, decreasing the effect of the PCV system..
Anyone ever have this issue?
Now there are many air foils out there.
When it comes to horsepower, the only testing I've read about is from Motor Trend.
Dyno Testing 7 Popular LT1 Engine Modifications
During testing, MT stated that
As for the blockage at the top...based on my own airfoil I just got, not much of an opening. However, the bottom opening leads to not only the IAC, but there is also a vertical grove behind the foil that may direct air upwards. I wish you had posted this before so that I could analyze the design. I can, however, suck (yikes) through the tube and gauge flow resistance (damn, this sounds all sorts of wrong).
My TB is still out of the car...awaiting refurbished balancer before I reinstall it.
I did see a video on youtube..a guy claimed his Holley band airfoil blocks all air flow, top and bottom causing issues. Looking face-on, it does not have the same opening as other airfoils; but I don't know if it has an opening underneath.
To be honest, this is the first time I hear of such issues.
Ric
I have a TPIs air foil and have used it on a couple of cars. In practice, I could feel no changes in power. The only thing I noticed was that at low speed when pushing the gas pedal I had a slight bog. I later replaced the computer chip and the computer was able to handle it without a bog.
The biggest concern is that the attachment screw can come loose and then get sucked into the engine causing lots of damage. If you are using an air foil make sure that you use a thread locker!
Good luck.
Personally, I think this test while valid does not fully explore all the possibilities.
- It's done on a TPI engine, which runs out of breath at 45-4800 RPM
- It's done on an engine that produced about 170HP to the wheels. Adding the 20% for drive train loss, this is a 205 HP engine? The 89 was rated at 230. Is this engine slightly hurt or just old?
- So they test with the stock intake ducting for base-lining and then remove it to test the airfoil and K&N filter. What did they do with the MAF? Did they run it in limp mode or open loop?
As smart allecky as they are on the video, they discredit themselves by adding variables and creating further speculation.
Do notice in the comments section...Jim Hall himself has a discussion with the two subjects regarding the test.
In my opinion, this piece of hardware is more suited to the LT1, and even more the LT4 where air velocity is higher.
I can see if there is no way for fresh air up to the top of the throttle body, then , yeah, I can see an issue.
I guess the question is, how much air is needed to allow the tube from throttle body to valve? That would be an engineering question.
My car has low tension rings, so, anything to assist in breathing pressure out of the crankcase is beneficial. My PCV goes through a coalescing filter, same type used on Air compressors.. It does collect oil.
Air Foil This post is different. I promise - CorvetteForum - Chevrolet Corvette Forum Discussion
See it in this pic at bottom
Was yours on an L98?
https://www.corvetteforum.com/forums...r-pcv-air.html
For me, this is enough to keep it in place.
