Question about pulling 1990 Airbag / Steering Wheel
I know I need to disconnect the battery and wait at least 10 minutes to allow the DERM to fully discharge (have had the battery disconnected for the last few days, actually). The FSM says that I need to also disconnect the connector position assurance and the yellow plug under the dash near the base of the steering column. No problem so far. But then the FSM says to "Install Load Tool J 37808..." None of the videos I've seen seem to do that. Is it necessary? If so, what's the purpose?
My inclination after having discharged everything for this long is to just disconnect the connectors, then pull the unit. If the load tool serves some purpose that protects the integrity of the SIR functionality, please let me know. It seems they are still gettable for not too much money.
Continue on when get the clocking coil take care with it not to let it move to much you don't want it to unspool or get over tightened so usually have tie wrap to hold it in place inner to outer so it doesn't get screwed up that assembly is hard to find so protect it
The cost on their web site is for a replacement switch. Which they no longer have in stock because they're basically obsolete.
They charged $195 to refurb my busted one. And it's firmer/stronger than OEM.
https://www.steeringcolumnservices.c...per-switch.php
I just unplugged my airbag. I didn't even unhook the battery.
The most pain in the rear end part of the whole thing, at least for me, was that dimmer switch setup. I cussed up a blue streak with that thing. Everything else was pretty straight forward. You're not going that deep into the column anyway.
Do NOT let your ignition fall out and dangle under it's own weight. Those thin wires WILL break. Best to tape it secure so it doesn't.
As an aside, I fought with that stupid dimmer switch arm for - no exaggeration - several hours. I thought I had it figured out and couldn't figure out why it didn't seem to work until I realized the actuator lever had fallen out of the recess in the actual switch way down by the floor boards.
The next thing I've got to figure out is how to get the key-in chime switch and retaining clip back in. The excellent video you mentioned in another thread from @jklumpp makes reference to it, but I can't figure out the exact orientation as to how they go in - whether I push them through together as an "assembly" or if the clip goes in first.
The parts I'm talking about are 16 and 17 from this FSM snip:
Do I just pinch them together as shown here and then push them into the recess where they mount?
It seems like the front edge of that clip should hook onto something, but it's not clear there's anywhere on the actual switch where it could clip without bending someting.
Last question for now, I promise: The FSM seems to suggest that I have to insert the key and turn the cylinder to RUN before putting in this clip and switch. Does that sounds right? So far I've had the key out and the cylinder in the lock position to prevent inadvertent motion in the wheels.
