crank no start
Old May 28, 2024 | 03:07 PM
stonesnpebbles's Avatar
stonesnpebbles
Default crank no start
i turned on my vette yesterday and while it was running it just randomly shut off and after that wouldn’t start. today i tested the fuel pressure and it was reading at about 42 so what do you guys think? it’s a 1986
Old May 29, 2024 | 12:26 PM
dburgjohn's Avatar
dburgjohn
If you have fuel then you likely do not have spark, enough spark or spark at correct time. I don't know your experience level but if it was mine I would pull a plug wire, put a spare plug in it and lay on metal surface. Then crank car to see if you have spark. Depending on what you see troubleshooting moves to the distributor or some other electrical part of ignition system. Good luck.
Old May 30, 2024 | 12:12 PM
stonesnpebbles
turns out my ignition coil was bad but when i replaced it i went to test the spark again and no spark so i open it back up and then the new ignition coil was bad again what do you think could cause that?
To crank no start
