1993 AC/ Heat blend
Old May 30, 2024 | 06:21 PM
carguy65's Avatar
carguy65
Default 1993 AC/ Heat blend
My electronics that control my AC and heat only blows down, the front vent button does not change air flow or combo of face and feet. The front defrost does work when set. The actuator does not click when other choices are made on the control. Green lights are not flashing and no codes on control. What could be the problem? I'm hoping its the actuator or heat control connections that may need to be cleaned
