1984 almost starts but doesnt
Old Jun 6, 2024 | 08:36 PM
ssro's Avatar
ssro
Default 1984 almost starts but doesnt
Hi so i got a c4 1984 and i changed the head gasket and shaved the heads of .005 and then reajust valves to specs, then put all back on and i tried to put the distributer back to where it was, and then i tried to start it, it feels like it almost want to starts but doesnt. I cant actually know whats the timming, i know its not 180 off because i already tried it, it did not start or make sounds at all, now i tried to put it back where it was with a picture i had, ql my spark plug are in the rigth place, it ran really good before removing heads, start easely, 2 - 3 and it would start. Please help
Old Jun 7, 2024 | 07:05 AM
ex-x-fire's Avatar
ex-x-fire
Twist the distributor a little if you're sure that its close.
Old Jun 9, 2024 | 06:07 PM
ssro's Avatar
ssro
I did, thats how the motor was getring better, but it just wont start, i mean even if its 10-15 degrees odf id still start, i feel like it migth be something else then timming at this point
Old Jun 10, 2024 | 06:51 AM
ex-x-fire's Avatar
ex-x-fire
Turn the engine over till the balancer points to the zero mark on the timing tab, then pop off the dist. cap, Is the rotor pointing at #1 or 180 off (that depends on which stroke #1 cylinder is at).
Old Jun 12, 2024 | 07:52 PM
ssro's Avatar
ssro
Yeah i was 2 slot off on my ignition coil, so i moved it 2 slots to clockwise to align it with my ingnition cap#1, had to start by putting it on tdc of compresion, when it was at peak, i removed the cap check when the ignion spinning thing was at and it was 2 slots off, it was fireing at 7 when it was supose to fire it 1, now it runs like a charm, timming was set at 8
To 1984 almost starts but doesnt
