C4 brake booster replacement .. pull the dash?
Old Jun 10, 2024 | 07:04 PM
Street89vette's Avatar
Street89vette
Default C4 brake booster replacement .. pull the dash?
Amazing hidden internal bolts (2) above steering column. Mirrors and spot lights just to see the nuts.
Do I have to pull out the dash/panels/steering/brake pedal/ floor insulation to get to these bolts?
Any other way?
Old Jun 10, 2024 | 08:59 PM
drive it's Avatar
drive it
i didn't remove anything inside-just have to become a contortionist lol.
Old Jun 10, 2024 | 09:44 PM
2011KLR's Avatar
2011KLR
And a wobble ended extension... one example of many options...https://www.harborfreight.com/profes...ece-56732.html
Old Jun 10, 2024 | 10:09 PM
dizwiz24's Avatar
dizwiz24
Remove drivers seat and contort yourself
Old Jun 10, 2024 | 11:31 PM
jv9999's Avatar
jv9999
Remove the seat (4x13mm), and use a 1/4" long wobble extention (10mm). Relatively easy actually.
Old Jun 11, 2024 | 08:21 AM
2011KLR's Avatar
2011KLR
Also. I happened to have several pallets nearby. I stacked 3 or 4 of them and used it as a bed to lay on. It helped to not be twisted multiple directions when i went in.
Old Jun 21, 2024 | 12:26 AM
Street89vette
thanks jv9999, it worked and anyone watching was surely laughing. Upside down 230lb 68 yr old with both legs sticking out of
the convertible top.
Old Jun 21, 2024 | 09:51 AM
84 4+3's Avatar
84 4+3
I sat on the floor next to the car and had it up in the front a little on some boards. Used a couple extensions. Booster plus master cylinder took maybe an hour... that included a couple cold snack breaks...
Old Jun 21, 2024 | 11:12 AM
Hit Man X's Avatar
Hit Man X
I have to do this too, ha. Do you guys have any pics under there for what I am looking for or will it just be blatantly obvious? I have swindled a shorter pal to assist (he is about 5'4") if that will help.
Old Jun 21, 2024 | 11:40 AM
Paul855's Avatar
Paul855
I removed the driver's seat. Nearly had to hire the neighborhood kid to get in there and get it out, but eventually I perservered. My back will be hurting for a month however.
Old Jun 21, 2024 | 11:56 AM
dburgjohn's Avatar
dburgjohn
I am 6" and not skinny. With the seat removed and wobble sockets I have done this repair several times on various C4s. Given the weather you may also want to set yourself a fan as you will be in that position for a bit.
Old Dec 27, 2024 | 02:08 PM
Street89vette
thanks dizwiz24 it worked
Old Dec 27, 2024 | 04:41 PM
dburgjohn's Avatar
dburgjohn
done this job many times. remove seat, extensions and a wobble joint. not a requirement but an electric or nematic ratchet seems to help keep socket from coming off the fastener but that is just my opinion.
Old Dec 27, 2024 | 05:02 PM
dizwiz24's Avatar
dizwiz24
Do not drop one of those nuts (and then replace it with a new nut) down into your gas pedal assembly
it caused my pedal to stick at WOT - engine RPM saw 7000 before i could shut it down with the key coast to a stop and fish out the nut from the gas pedal assembly
Old Dec 28, 2024 | 10:35 PM
Gale Banks 80''s Avatar
Gale Banks 80'
When you get the old one out measure the hole that attaches to the Brake Lever with the new one. More than one person has bolted the new one in only to find the hole is too small and doesn't fit. Use some Duct Tape and put it across the top of the Carpet so the Nuts can't fall between. You might warm up by changing out a couple of Boosters on early C3's. The C4 will seem like a breeze.
To C4 brake booster replacement .. pull the dash?
