Early Rev limiter
Old Jun 14, 2024 | 10:11 AM
hbk_bkk's Avatar
hbk_bkk
Default Early Rev limiter
1995 LT1 car. Second gear. If I push to the rev limiter on the street, it kicks in where I’d expect around 5800 rpm, 69 MPH.
however when I’m doing Autocross, the limiter/fuel cutoff usually happens around 5000 rpm 60 MPH.
Is this normal? Why does it happen? Why is it not hitting 5800 rpm before it starts cutting fuel?
Old Jun 14, 2024 | 10:42 AM
jmgtp's Avatar
jmgtp
Auto cross, lateral Gs, fuel sloshing away from the pickup perhaps? These cars are known for it when low in fuel. Mine will do it on the street under hard acceleration when low, even before the reserve is indicated.
how full is your tank when this happens?
Old Jun 14, 2024 | 11:18 AM
hbk_bkk's Avatar
hbk_bkk
I run half a tank, and it usually happens when I’m going on a straight.
I think my clutch is due for a replacement. I’m wondering if when I mat the accelerator, maybe the engine is spooling up to 5800 rpm and the clutch starts slipping around 5000?
Old Jun 14, 2024 | 12:42 PM
jmgtp's Avatar
jmgtp
An eye on the tach should answer that question, but then I’d expect it to happen on the street too, not just auto x. Maybe a heat soak issue and opti or something else is calling it quits at high rpm? Datalog if you have the means, might be revealing.
Old Jun 14, 2024 | 04:39 PM
C4industries's Avatar
C4industries
It could be fuel slosh. My C4s will pull air and the engine will cut out at 1/2 tank under hard acceleration. Try running with a full tank of fuel at the next event.
To Early Rev limiter
