When car is a little hot sometimes it doesn’t want to start but when left to cool down, it starts right up. The o2 sensor does need to be replaced and the computer says it’s also bad but is that what it is? Is it failing under the normal engine run from the heat cause it’s faulty? Or should I be looking elsewhere?
in cool weather and/or rainy weather it runs great
in muggy and/or hot weather, it doesn’t like to run the greatest.
also a smell of fuel is present when running it like it’s kinda rich.
Car randomly dies on idle rpm range.(clutch + stops)
but starts right back up.(it’s cool today)
will be replacing o2 been holding out cause there’s also a possible ground fault
i Feed it gas, didn’t want to have to feed it sensors as well. But at least I can see how long this will go before it goes bad.
