While rotating my front disks (because my former mechanic put the right on the left, etc, don't ask) I noticed that the service manual says:
"---remove two bracket mounting bolts and washers - Discard mounting bolts"
and further on it says: "-New bracket mounting bolts will come with an adhesive already applied to the threads",
and further " tighten to 225 N.m (166 lb.ft.)"
So I used the old bolts with red locktite.
Are the bolts over torqued and dead, or is this just because GM wants to sell more bolts, or they don't believe in locktite and use something special?
My guess is that they coat all of the bolts with a precoat type locktite at the factory to speed installation on the assembly line, and just recommend that same bolt as a replacement because they can.
I reused mine as well, I had one that had beem rounded off by some previous nurd and fitted a 10.6 grade metric cap head screw, (much easier to undo). I used blue loctite. Will you be able to remove them OK with red loctite?.
To release the red loctite, use a heat source on the bolt until the loctite burns off and stops smoking. Then wait for the bolt and the surrounding area to cool before removing the bolt.
(I've found that the blue loctite is sufficient for holding these bolts in all driving conditions from auto-x to track days.) :yesnod:
From: No more yankee my wankee, the Donger is tired!
Re: Discard Mounting Bolts? (mr.beachcomber)
GM engineers will always error on the side of caution. Unless your doing some heavy duty track racing you should be all right, but then again new ones aren't that expensive. 84 CF 91 ZR-1
Like the others here, I reused mine as well. As an aside, those bolts are about 2X the thickness of whatever else you're steering around as a daily driver.
Full blown raod track braking aside, I can't imagine them ever failing. The only consideration I'd give here conserns the fact that normal street sedan caliper bolts pass through "rubber" bushings. The C4 bolet is metal to metal. that might cause additional shock loading. Maybe that's what the general had in mind re: replacing them.
Cire96
