What are your thoughts on this compressor failure?
Old Jul 5, 2024 | 11:00 PM
OneRedVette's Avatar
OneRedVette
Default What are your thoughts on this compressor failure?
Solved: Appears to have just been a compressor clutch failure
Hello all. Anyone have any ideas on how my compressor failed?
I was driving for over two hours on the interstate with the AC working just fine, but as soon as I took my exit and stopped at a stoplight, my air went warm and I smelled burning rubber/clutch.
I shut the AC off until I had a chance to look at it.
When I got home I found the compressor clutch had melted and slipped within itself. (The clutch itself is two concentric parts with a rubber bushing, almost like a harmonic balancer). It had slung melted rubber all over my engine/hood
I turned the AC on and the clutch engaged the compressor just fine, but the compressor failed compress. It just sits there and spins, but will not move freon. However, after evacuating the system and checking the compressor, it still creates strong vacuum and high pressure, even when I'm slowly spinning it with a drill.
Next, I thought there might be a blockage in the system, but I can blow through it with compressed air. Any ideas? 1995, R-134a
Old Jul 6, 2024 | 12:05 AM
arbee's Avatar
arbee
So now I have a failed compressor, but I don't know what could've done it. Any ideas? 1995, R-134a
Things wear out or break. Nothing lasts forever. There doesn't have to be a "reason".
Old Jul 6, 2024 | 12:48 AM
OneRedVette
True. I just find it interesting that it seized then spun freely later
Old Jul 9, 2024 | 10:09 AM
OneRedVette
Upon further inspection, the compressor appears to work properly and it was simply a clutch failure. Getting another clutch and trying again.
Old Jul 10, 2024 | 08:34 AM
C409's Avatar
C409
I had a similar failure on my Suburban tow vehicle . Burned up 2 clutches in the same fashion ... melted the rubber ring ... it turned out to be a corroded ground wire that was preventing the clutch from receiving full voltage . Once I cleaned the connection and replaced the clutch again all was well .
Old Jul 12, 2024 | 07:58 AM
OneRedVette
Yep it was the clutch. I filled the system with compressed air and used a drill on the compressor to monitor the pressures. It did everything it was supposed to, so I vacuumed the system, recharged with freon, and tried it out with a different clutch. I shimmed the clutch to 0.020 too.
Works great again!
I ran it for quite a while and the pressures remained good, with low side in the 40s and high side in the low 200s
And that's a good idea about the clutch ground. Any idea where that comes from? I've cleaned the primary ground under the battery on the car before. I've noticed there is one near the blower attached to the frame rail.
My diagnosis of the original clutch failure:
It began slipping one way or another, as the clutch surface and idler pulley looks like a real clutch/flywheel when it slips. Full of heat discoloration and hot spots. It must've gotten hot enough to melt the rubber ring and begin slipping on the rubber instead. At this point it could not turn the compressor at all.
Old Jul 17, 2024 | 07:21 AM
C4 Steck's Avatar
C4 Steck
Oneredvette, this is perfect timing. My dad’s car is having an issue with the compressor clutch. I don’t know if the source of the rubber is the belt slipping around the pulley or something internal but it’s an obvious clutch problem. The center part of the clutch wobbles when you press on it. It’s coming apart. Anyway, just wondering where you sourced your clutch from? I believe the compressor is totally fine and car only has 30k on it.
Old Jul 17, 2024 | 12:12 PM
OneRedVette
I pulled mine from a 1989 corvette. Didn't buy a new one.
Old Jul 17, 2024 | 01:50 PM
C4 Steck's Avatar
C4 Steck
Ah ok
To What are your thoughts on this compressor failure?
