Cannot shift 6-speed into gear
Old Jul 6, 2024 | 04:30 PM
Rubyred's Avatar
Rubyred
Default Cannot shift 6-speed into gear
I backed my 1993 6-speed out of the garage. It made a strange sound and acted funny (not in a humorous way). Now it will not go into any gear. The strange thing is if I push in and hold the stick in the first gear position it rock forward an inch, or so. I have 60,000 miles on it (original owner).
I assume that is either the clutch or linkage. Before I flatbed it to a local mechanic I thought I should get available advice from the Forum.
Thanks.
Old Jul 6, 2024 | 04:50 PM
Topduarte's Avatar
Topduarte
Change the clutch fluid.
Old Jul 6, 2024 | 05:10 PM
dizwiz24's Avatar
dizwiz24
Probably the seal in the clutch slave is blown and you have no fluid
fill with fluid and bleed (and keep an eye on the leak)
and/or replace the slave
Old Jul 7, 2024 | 12:27 AM
Gale Banks 80''s Avatar
Gale Banks 80'
If the Clutch feels normal has it probably has fluid in it. When the engine if off will it shift into any gears ? If so then put it in gear and depress the Clutch and see if the car rolls either on a incline or with somebody pushing.
Old Jul 7, 2024 | 07:10 AM
Rubyred's Avatar
Rubyred
Thanks to everyone for your responses. We are busy with our 50th wedding anniversary today, so I will work on this later this week.
Old Jul 9, 2024 | 07:18 PM
auburn2's Avatar
auburn2
It is almost certainly a problem with air in your clutch system.
Old Jul 10, 2024 | 05:36 PM
ductape's Avatar
ductape
Cruise-In V Veteran
Congrats on the 50th Anniversary!!!!
Old Jul 10, 2024 | 07:21 PM
Siveck's Avatar
Siveck
Should probably tell wife you need to work on Vette on 50th anniversary. 😳
Old Jul 10, 2024 | 07:26 PM
Topduarte's Avatar
Topduarte
You will be sleeping with the dog if you u worked on the vette.
Old Jul 10, 2024 | 07:40 PM
Siveck's Avatar
Siveck
Originally Posted by topduarte
you will be sleeping with the dog if you u worked on the vette.
To Cannot shift 6-speed into gear
