No start
Old Jul 7, 2024 | 04:17 PM
Woody-1's Avatar
Woody-1
3rd Gear
Default No start
I am currently experiencing a no start situation. My 1986 will turn over but will not start. I have replaced the following ignition coil, pick-up coil ICM, new cap rotor wires plugs and new points. But still will not start. I have also tried VATS by pass still nothing. Has anyone out there experienced this. The original problem started I was returning from a drive was backing the car into its spot and I suddenly quite and wouldn't start back-up. Also I do have power to the distibutor but no spark and I do have fuel pressure. If anyone was any ideas I would appreciate it if you could share. Thanks.
Old Jul 7, 2024 | 04:21 PM
Elduderino's Avatar
Elduderino
What is your fuel pressure?
Old Jul 7, 2024 | 04:38 PM
Woody-1's Avatar
Woody-1
3rd Gear
I have fuel pressure I believe it was 40lbs. I just replaced the injectors as well about a year ago. And the fuel filler and fuel pump 3 years ago.
Old Jul 7, 2024 | 07:51 PM
Elduderino's Avatar
Elduderino
You believe? Spray some brake cleaner in the TB and see if she fires.
Old Jul 9, 2024 | 10:51 PM
Woody-1's Avatar
Woody-1
3rd Gear
Nope no fire in the hole.
To No start
