Vacuum lines and throttle cable issue
Old Jul 12, 2024 | 06:14 PM
Swervin91Vette's Avatar
Swervin91Vette
6th Gear
Default Vacuum lines and throttle cable issue
So I’m wrapping up my cam swap on my ‘91 and I did large tube runners, lower intake, and upper intake with a 58mm throttle body I bought off eBay that was on a TPI Camaro. After I got everything on the car and I started connecting hoses. I realized that the upper intake did not have 3 vacuum line connectors that mine did for the MAP sensor. I would rather not drill and tap a hole to put another vacuum fitting. Can I splice the vacuum line for the brake booster or the fuel pressure regulator to connect to the vacuum line for my HVAC? Also the throttle bodies were different and have a different style throttle cable connector. I think I’m gonna by a Camaro throttle cable and swap mine out. It’s a manual car so I’m just swapping the throttle cable that wraps around on my car but the new intake has a hole.
