Running lights
Old Feb 2, 2003 | 03:22 AM
C490Vette's Avatar
C490Vette
Default Running lights
Does anyone know of a kit to have the front runnings lights come on at all times like the C5's for a 1990? I am sure there is a way to do it with just some wires and a switch but I thought I would check for an actual kit before I got messing around with the wires. If there isnt a kit, can anyone give me some pointers on doing it myself? Thanx!
:thumbs:
Old Feb 2, 2003 | 02:19 PM
white90conv's Avatar
white90conv
Default Re: Running lights (C490Vette)
You can do it yourself with a relay and possibly some diodes. You need a schematic to idendify the wires. There is a large wiring protector running along the left hand side of the engine compartment that contains most if not all of the wires you will need.
I installed one on my car. It operates the running lights and the fog lamps but not the headlights. I also connected the ground side of the relay primary to the starter relay hot side (not chassis ground) so that the lights will not operate when trying to start the car - a help if your battery is weak.
Old Feb 2, 2003 | 10:25 PM
StarShipCmdr's Avatar
StarShipCmdr
Check this site:
http://www.webelectricproducts.com/products.htm
Old Feb 2, 2003 | 10:35 PM
C490Vette's Avatar
C490Vette
Default Re: Running lights (StarShipCmdr)
Thanx StarShip!!!!!! Exactly what I was looking for!!! :thumbs:
To Running lights
