No centre cluster lights or LCD
Old Jul 20, 2024 | 02:25 PM
Mt150's Avatar
Mt150
6th Gear
Default No centre cluster lights or LCD
1995 , no cluster back lights , no LCD display , got a rebuilt one still no change.5a Fuse has no power to it . I have tried a new BCM still no luck. Grounds seam ok ? Tach and gauges work on cluster. Any help would be greatly appreciated.
Old Jul 20, 2024 | 03:43 PM
FrankieD's Avatar
FrankieD
Check "Cluster Fuse #27" and "LCD Fuse #38"
Also check Instrument Cluster Connector Cavity A7 CKT 150 ( Ground) for an open
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jul 20, 2024 | 07:48 PM
Mt150's Avatar
Mt150
6th Gear
Default Thank you
Thanks for the information, I’ll keep you updated
Old Jul 24, 2024 | 12:38 PM
Mt150's Avatar
Mt150
6th Gear
Default Location of grounds
I’m trying to test all the grounds to see if that’s part of my issue, I have no horn, no interior lights when the doors open, no dash back lights in cluster. Still no LCD display. Third row of fuses have no power to them ??
Old Jul 24, 2024 | 03:56 PM
FrankieD's Avatar
FrankieD
There are Two maxi -fuse blocks that are located under hood near battery. Check Fuse #1 in the "Forward Lamp Fuse Block" for Interior Lighting
Old Jul 25, 2024 | 04:54 PM
Mt150's Avatar
Mt150
6th Gear
Those have all been checked and are good. I have interior lights when I turn the dimmer on the head light switch all the way on.
Old Jul 29, 2024 | 07:48 PM
Mt150's Avatar
Mt150
6th Gear
Default Think it’s the CCM?
Could the ccm be my issue? Reading up on this. Just wondering if it can be programmed or checked with a scan tool to determine if this is the issue
1995 C4
Old Jul 30, 2024 | 09:49 AM
FrankieD's Avatar
FrankieD
Everything you need to Diagnose and Test CCM Functionality is listed in this CCM Section. Lots to absorb so take your time and re-read several times if needed. The fun of troubleshooting is only possible through proper information.
File Type: pdf
Old Jul 30, 2024 | 07:59 PM
Mt150's Avatar
Mt150
6th Gear
Default Thank yiu
Thank you so very much
Old Jul 30, 2024 | 08:48 PM
NickPSI's Avatar
NickPSI
In my 85 I had a ton of these that were opened too much and needed to be replaced in the fuse panel itself. Granted, your car is much newer but its worth a look.
Old May 19, 2025 | 08:06 PM
Stephen19231's Avatar
Stephen19231
8th Gear
Default Help
Did this ever get solved!!? I’m having the EXACT same issue on my 94. Just ripped the CCM out and tested that. Need some more help please!
To No centre cluster lights or LCD
