Shift Kits?
Old Feb 2, 2003 | 02:36 PM
flyinace2000's Avatar
flyinace2000
St. Jude Contributor
Default Shift Kits?
What do they do to the tranmsission and how do they do it?
-Will
Old Feb 2, 2003 | 04:02 PM
CL's Avatar
CL
Default Re: Shift Kits? (flyinace2000)
It depends on the kit you get. Basicly the kits will have you drop the valve body and change servo springs. Some kits have you drill holes in the valve body. I would not ise the B&M kit for the 700R. It is cheap and will not give you the shifts you are looking for. TransGo makes a nice kit. Search the post I am sure it has some good posts on the subject.
Old Feb 2, 2003 | 08:54 PM
flyinace2000
Default Re: Shift Kits? (CL)
what are they and why do people install them?
Old Feb 2, 2003 | 10:46 PM
cprgmr's Avatar
cprgmr
The stock auto tranny is made for nice easy shifts which leads to good fuel economy. A shift kit changes the fluid flow in the valve body (among other things). People install them to create firmer shifts, thus allowing your transmission to get into gear quicker and provide a "performance increase".
Old Feb 3, 2003 | 03:09 PM
JDANNER's Avatar
JDANNER
I installed a Trans Go shift kit (Jegs.com) and I'm not autotrans expert by any mean but what it will do it to give you much quicker & firmer shifts under hard acceleration but increasing the line pressure in your tranny. Fluid is what makes your autotrans work, both in the converter and trans itself. The kits have you replace soleniods, remove or change metal *****, drill out ports Etc. all to increase fluid flow. I hope that helps :cheers:
Old Feb 3, 2003 | 04:03 PM
flyinace2000
Default Re: Shift Kits? (JDANNER)
thanks that was very informative! :lurk:
To Shift Kits?
