Question for Jesse(ski_down_it)
Old Feb 2, 2003 | 03:42 PM
CL's Avatar
CL
Default Question for Jesse(ski_down_it)
I posted that I installed a Superram intake and had a performance loss. The car runs fine no vaccum leaks or timing problems. Just the same level of power as with the stock intake. A lot of user stated that you programmed chips for them. I wondering if you could give me some tips ot advice on what you changed for the superram. I have done a eproms for TPI cars with stock intakes with good results. I have never changed the MAF values and I am not sure what tables to adjust for the superram setup. The custom chip I am using now is based off of the ARAP. I use tunnercat to make changes. If it would help email me at clee@summtiholdings.com and I will send you the bin file I am using.
Mod's to engine are complete superram setup, no cats dual 2 1/2 exhaust with flowmasters, 3.73 gear,K&N filter, Air foil, a custom chip.
Old Feb 2, 2003 | 04:12 PM
chucks88's Avatar
chucks88
Default Re: Question for Jesse(ski_down_it) (CL)
ski_down_it@yahoo.com
